Instrument shrouds
Ade B
Instrument shrouds
Post by Ade B »
The rings/shrouds on my RS/S conversion won't stay put. It looks like a PO has replaced the glass at some point and the indent around the interface between glass and housing is uneven. The shrouds which were on the bike at purchase fell off on journey home from the vendor but luckily I managed not to lose them. They are showing their age, and have lost much of their elasticity.
image from the MAX BMW Motorcycle mirofiche, part no.1
Interestingly it is recommended to glue them in place when replacing, in which case I see little point in purchasing new replacements.
I've got to go back into the instruments at some point to replace a screw which has escaped from the speedo dial and is rattling around behind the glass... Any suggestions for an appropriate none permanent adhesive in the meantime?
Cheers
Ade
Re: Instrument shrouds
Over the years I've found that a trickle of water can accumulate at 6 o'clock on the dial face and a little may seep down and eventually the soft metal circumference strip deteriorates. With that in mind, I'd be inclined to try some silicone from 4 to 8 o'clock.
r67boxer
Post by r67boxer »
I've used Dowsil 732 with success on glass and 'eyebrows' on the instrument cluster. Stays flexible so not permanent.
Dowsil 732.jpg (35.88 KiB) Viewed 23326 times
Ade B
Post by Ade B »
Thanks both, I've a tube of silicone somewhere I'll dig out.
Ade B
Post by Ade B »
Glued them on with a multipurpose silicone goo I've had in the freezer for ever...let's see how long they stay put!
