1977 R100RS - brake and electrical questions
Posted: Wed Dec 17, 2025 7:59 pm
Hello,
I am helping a friend get her '77 R100RS running and rideable so she can sell it and I have run into a couple issues. First off are the brakes. The brake fluid was pretty grim so I pulled the calipers and took them apart (a link to a video about the bike is below). I expected to find the pistons rusted, but they looked much better than I expected (except the recesses on the side that presses into the back of the pads). I ordered new seals, pads, o-rings and and pressure switch (that was dead too) and started reassembly. When it came time to slide the pistons into the caliper, they didn't want to go in. I lubricated both the new oil seal and the walls of the piston with brake fluid, but it was way harder to press them in than I've ever experienced on a brake rebuild. Now that I'm at a point where I'm trying to bleed them (still working to build pressure, but had to take a break), they grab the disc, but don't fully release. When you let go of the lever, the wheel will turn with force, but mot easily. Is this normal? Am I missing something?
As mentioned, I had to take a brake from trying to fully build pressure (hoping there isn't a master cylinder rebuild in my future). While taking the break, I figured there was enough pressure that I could confirm the brake light switch is at least working and that the brake light would now come on. When I turned the key, I found the battery was completely dead. It is only a few weeks old and shouldn't be unless there is something drawing on it.
It was so low that at first I couldn't even get the battery tender to charge it (just gave the flashing red "not charging" light). I gave it a bit of a boost from a jump pack and tried the battery tender again. Now it was at 4v and giving a solid red light indicating it was charging. After a bit of puttering with other things, I heard a re-occurring clicking sound. It sounded like a relay and I confirmed it would stop if I disconnected the battery negative. I traced it to the horn relay that sits to the left of the master cylinder by the frame. Previously (in the video below), the horn wasn't working until had pushed on that relay a bit. I think the reason it is clicking is that the voltage is so low it can't hold the relay contact closed and it keeps falling back to open and I didn't hear the clicking before because the battery had enough power to just hold the relay closed. Now I need to figure out why there is power at the relay when the key is out of the ignition. I'm sitting down with a wiring diagram to try and figure it out, but if anyone has any ideas or think they can point me in the right direction, I'd love to hear them.
https://youtu.be/4Y9jugE1g-o?si=UNZRxbcJeZd-akFZ
Many thanks,
jason in Seattle / 6 Bike Garage
Many thanks,
