small end bearing installation advise needed
mattcfish
Post by mattcfish »
I feel I should replace the small end bearings on my connecting rods. There is the slightest amount of detectable play. The big ends were polished down to the limits, so I think these have racked up quite a few miles. I have them off the bike right now, and I have a new set , so what the heck. Is this something that can be done in the home shop? I've got a big vise and the talent for fabrication. If not, is this one of those things that requires the expertese of an airhead tech...or can I bring them to a reputable local shop that does work on VW's and everything else?
R90Steve
Re: small end bearing installation advise needed
Post by R90Steve »
A good automotive machine shop can press the bushings in and fit them to your pins.
Do not let anyone size them by pressing a ball through it. It is done by a special reamer, or hone. Parallel with the crank is a good thing too.
I have only done them on the /2 type built up cranks, so I have no other advice about your quest. Let us know what you find.
mattcfish
Post by mattcfish »
Duane Ausherman wrote:Do not let anyone size them by pressing a ball through it. It is done by a special reamer, or hone. Parallel with the crank is a good thing too.
Of course, It's getting more complicated. The simple airhead, as alway, requires specialized repair.
I take it that these aren't replaced very often. How much tolerance is allowable for pin fit? How does everyone else determine when they need to be replaced. The play in mine is barely detectable.
R90Steve
Post by R90Steve »
My factory /7 manual calls for .00059"-.00102'. So basically a half to one thousanth. Can you feel a thousanth? I think if you can feel play, they are loose.
A good automotive machine shop, will be one that re-sizes rods and will be able to take care of your needs.
I too think that any play is too much. To get a pin into the bushing, you have to have it really lined up.
