I woke early today...
Deleted User 61
Post by Deleted User 61 »
...and the R65 frame kept calling to me...
I've decided to have it and the swing-arm powder coated.
I will be removing a drive shaft (cush-drive) for the first time.
Since it is possible my swing-arm was tweaked in the crash, I've decided to use the one that came with the frame.
I had my grinder out removing the last traces of the front coil mount, that failed in probably 95% of these early Type-248's.
I removed the steering head bearing races a while back, before I thought I would have the frame painted. Should I worry about these points being exposed? I've left the races in the swing-arm.
Re: I woke early today...
Remove the races from the swingarm if you are going to reuse them.
When you go to the PC, spend some time with the actual PCer and not just the estimator going over what gets masked for both the blasting and the PC. If you don't, you will spend $$$$ on taps to clean out threads you didn't even know were there. Particularly the swingarm pivot pin threads (DAMHIK).
Make sure the motor mount holes get masked, and even then, expect to do some clean-up on the holes. If your sidestand pivot is part of the frame, make sure it's masked or you'll be a while shoeshining the PC off it to get the sidestand back on.
When you get it back, hang it by the head tube and whack it gently with the heel of your hand a few times and watch for stuff coming out the top tube. Keep doing so until nothing comes out. Then hang it by the SA pivot or rear cross tube and do the same. Compressed air is your friend here. Make sure the swingarm, as well, is clear of odd dust and unmelted powder.
Perhaps we'll be riding soon, both of us?
Deleted User 61
You have a big head start on me!
And I don't think "winter" is quite the same for you, either. ;)
Waking early with bike rebuilding thoughts is indicative of something important Rob.
You have wind in your sails. Go for it, mate. Yay.
ps: I jumped out of bed at 4:30 this morning. Gearbox is in. Just putting the final drive back together. Double yay.
Deleted User 61
The powder coater offers two blacks in their "stock" colors, a Satin Black and Gloss Black.
I would think our frames are more of a semi-flat?
R65 Rob wrote:The powder coater offers two blacks in their "stock" colors, a Satin Black and Gloss Black.
Once you go shiny you'll never go back! At my local PC, gloss black is officially called "Bike Black."
Clean up a representative spot on your frame (top tube, maybe?) and compare it to your PC folk's sample. I think you'll be in between Satin and Gloss.
Mel, I looked at that pic for quite a while, wondering what the hell seemed weird about it.
Then it came to me.
There is paint on the frame tube under your master cylinder.
Definitely not stock.
It's ok, mate. You'll prolly get away with it.
Deleted User 61
Does this mean I have to scrub my engine, transmission and final drive cases to match the splendor of the frame and tank?
And then try and keep it that way?
Hmmm...
Max Headroom
Post by Max Headroom »
R65 Rob wrote:Does this mean I have to scrub my engine, transmission and final drive cases to match the splendor of the frame and tank?
Hmmm...
It could be worse than you realise, Rob. Before long, you'll buy a trailer so that you can display the bike at shows . . . . :twisted:
- Mark Twain
Deleted User 61
Max Headroom wrote: It could be worse than you realise, Rob. Before long, you'll buy a trailer so that you can display the bike at shows . . . . :twisted:
I wouldn't have to bother with the expense of license or registration! Or all that cumbersome riding gear! :lol:
