Carb air intake tubes...repair??
Posted: Fri Aug 27, 2010 2:18 pm
Just as expected..going on a trip tomorrow on the 74 R75/6.
Had rebuilt carbs, valves clearances checked and tweaked, points gapped, timing checked - spot on, carbs synce'd and ready to go...NOT
Out for good long run yesterday make sure everything ready to go but high idle after good warm up. Did usual check to see if advance unit was culprit..nope...new springs ordered from Motobins as back up but advance unit working fine.
Hmm...had to be air getting in somewhere...sure enough right upper carb air intake was split up by airbox clamps (lower one)...ahaa...air pouring in through here. If tighten up clamps too much it just widens the split. Guess I cracked lip on carb installation...not taking the required beer before assembly obviously...damn...nearest dealer 250kms in opposite direction to trip...so what to seal up with???
I've used Black RTV sealant (gasket silicone) in the past and got me through a jam...any other ideas that might work?? Gonna be gone couple weeks... maybe spot a BMW dealer Stateside and see if can get one is other possibility.
Radiator hose if I could find right diameter?? Also thinking if I could find right plumbing rubber connector...kind you see at plumbing/hardware store to join two pipes together with clamps..might work if went over top of existing air tube and coupler? Heavy guaged PVC bag to wrap around and help seal?? Condum...oops don't have any around...I'll check with the young lad see if has a few extras for the old man!
Any other "quick fixes" or suggestions out there??
PS: Our group consists of my 74 R75/6, me friend John(boy)'s 72 R60/5, buddy Chris' 76 R90s and a rogue Brit Classic (maybe) 62 Norton Dominator...should be a hoot...always is! Pix will follow someday on return.
