Quick speedometer question!
72R75
Post by 72R75 »
Ok I just got my bike back from getting the forks resealed and ordered some progressive air shocks for it. I need to send my speedometer off to get rebuilt/repaired. I was wondering, Will the bike still run and function without the speedometer installed? I have a handle bar clip for my I phone and I will use that for my speed until I get mine back.
thanks,
Jr
Re: Quick speedometer question!
Post by Deleted User 62 »
The bike will run, but it will not charge without the generator light in the circuit.
Tim Shepherd wrote:The bike will run, but it will not charge without the generator light in the circuit.
You can rig a jumper with a small resistor and then all will be well. You just need the schematic to identify the correct wires to jump. Apparently a 330 ohm 1 watt resistor is appropriate.
Motorrad Elektrik has a little kit:
http://www.motoelekt.com/genlightacc.htm
I used exactly that . It works.
