In putting things together on the GS, I now have leaking fuel connections at the tee's coming from cross engine fuel line.
I really like the BMW braid covered line because it is easy to bend and get on and off. But, it seems to only last about a year.
I have some auto 1/4 inch fuel line that fits, but it is fatter and harder to bend around. Anyone have suggestions?
thanks,
Don
Fuel line- wadda ya use?
'83 R80ST
'92 R100GS
'04 R1150RTP
'92 R100GS
'04 R1150RTP
Re: Fuel line- wadda ya use?
The MaxBMW fiche shows a thin wall unbraided tubing for R100GS. This is what I use and it's the bees knees:
- Ken in Oklahoma
I use 1/4" automotive fuel line. It's cheap(er), readily available, and I can live with the stiffness. And it's tenacious, sometimes being a bit difficult to slip off the petcock or carb nipple. The last part isn't a virtue, except that I don't worry much about leaks.
My 93 GS still had the factory BMW branded hose beneath the air box.
It was marked 6 mm x11 mm and was unreinforced rubber similar to the hoses on most Jap bikes, and available from any Jap bike dealer, together with neat little spring clips.
Like Ken I use the best hose I can find , which for me is the 6 mm reinforced pressure hose intended for the low pressure injection systems fitted to most auto's today.
It only seems to come in with the correct code to denote resistance to whatever it is in todays gas that causes the damage - and it isn't the alcohol.
It doesn't need clips as it gets a decent grip on the nipples, and will probably last the life if the bike.
I'm using some thin walled stuff also. Its quite soft but appears to be doing its job ok after a couple of months.
I like a little grease on the barbed connectors, makes it easier to remove the hose when I want to. No clamps either.
Hello All - new here...
I have begun using and would recommend this yellow PVC fuel line from McMaster-Carr:
http://www.mcmaster.com/#catalog/119/123/=n5b5cg.
5552K25 Fuel and Lubricant Yellow Tygon PVC Tubing, 1/4" ID, 3/8" OD, 1/16" Wall Thickness, 20' Length
Formulation: F-4040-A
I believe I read about it in a Snowbum article. So far I'm very pleased with it, and it is supposedly not affected by light, and especially important it is impervious to gasoline and the ethanol additive in our fuel.
I also place a washer on the petcock tube before slipping on the tubing. It makes line removal very easy.
I'd post an image but it appears I am underprivileged, being a newbie.
Bg
Bg
Just make sure that whatever you use will work with today's fuel, the last time I used no name fuel line it rotted within 12 months.
I have the Motobins cloth covered stuff. It's fine and has lasted well.
A fellow @ Advrider suggested that once cut, the cloth ends dipped in superglue prevent the cloth from fraying.
- DucatiPete
I use m'bin hose. It's pretty cheap, looks good and it seems to last well. The superglue tip sounds worthy. I used some clear nail polish (I use for my camera gear ) but it doesn't stop the fraying...
Brilliant! Thanks!Bgarceau wrote:I also place a washer on the petcock tube before slipping on the tubing. It makes line removal very easy.
Bg
Don
'83 R80ST
'92 R100GS
'04 R1150RTP
'92 R100GS
'04 R1150RTP
