Pre '81 Filter Housing
Posted: Sat Oct 09, 2010 1:01 pm
by Nourish
Hello.
Does anyone know what the differences are between the different part numbered pre '81 Filter Housings?
Re: Pre '81 Filter Housing
Posted: Sat Oct 09, 2010 10:03 pm
by vanzen
Nourish wrote:Hello.
Exactly what is it that you want to know, Nourish ?
I know some things but I'm not sure what it is that
you want to know ...
What ya doin ... or tryin' to do ?
Posted: Sun Oct 10, 2010 1:23 pm
by Nourish
Well I went to an autojumble and picked up a pair of casings and when I got home I realised I had two left handed ones! The sleeves for the carb connecting pipes are different and one has holes in the rear. What I'm trying to do is fit a /5 tank to my Mono, after sorting the electrics so that they will clear the tank I found that the tank fouled the air filter box - so I want to use the pre '81 filter housing and need the best ones using 40mm Bings. Cheers
Posted: Sun Oct 10, 2010 2:01 pm
by Deleted User 287
Nourish wrote:Well I went to an autojumble and picked up a pair of casings and when I got home I realised I had two left handed ones! The sleeves for the carb connecting pipes are different and one has holes in the rear. What I'm trying to do is fit a /5 tank to my Mono, after sorting the electrics so that they will clear the tank I found that the tank fouled the air filter box - so I want to use the pre '81 filter housing and need the best ones using 40mm Bings. Cheers
It sounds like you need to go back to the junk yard and trade in a left for a right.
Posted: Sun Oct 10, 2010 2:07 pm
by wirewrkr
OH, you mean
pre 80 airbox halves.
Here in the states the 80 was the first year for the flat aircleaner.
had me confused for a minute.
There was no specific air box for the 40mm carbs, it was all made up with the rubber attachments.
The 77RS is the bike I use for reference when doing what you are doing. I guess you had to relocate all the tabs under the tank for the electrics?
If it's any consolation, the airtubes never fit that well on the 40mm Bings with the aluminum airbox.
They only had to deal with it for 3 years so they didn't try to do anything spectacular with the fitment.
Posted: Sun Oct 10, 2010 11:17 pm
by kreece
Well I pulled the shaft apart and as Stephen suggested, the spring was broke. Should be an easy fix. Thanks for the replies.
Posted: Mon Oct 11, 2010 11:26 am
by wirewrkr
HUH?
What's that got to do with an airbox?
Posted: Mon Oct 11, 2010 1:45 pm
wirewrkr wrote:HUH?
Oh good. I'm not the only one who got confused...
Posted: Wed Oct 13, 2010 2:34 pm
by Steve in Golden
My guess is, Kreece responded to the wrong thread... My bet would be, he meant to respond to
this thread.
Major Softie wrote:wirewrkr wrote:HUH?
