Does anyone know if the circuit board for the speed o,tach and idiot lights is available anyplace? I can't find it on the microfish.
1979 R100RT
Airhead circuit board
Re: Airhead circuit board
pm sent.
They do come up on ebay periodically. However, they're getting more expensive quickly.
The newer post 1981 versions are more common and luckily for those owners the mono boards also fit them.
The pre 1980 are becoming difficult to find in perfect working order. Not impossible though.
There's one specifically for your bike on FleaBay right now. Just saying.
You can have a buncha fun with some wire and solder. Then maybe get only another 30 years out of it.
That said, the instrument illumination does wink in and out on mine. I'd spend an afternoon to fix it if I rode at night. All the warning lights are functioning.
- Ken in Oklahoma
melville wrote:You can have a buncha fun with some wire and solder. Then maybe get only another 30 years out of it.
That winking in and out happened to me on my '76 R75/6. After much wringing of hands and gnashing of teeth I figured out that the problem was a bad connection between the instrument cluster connector pin and the adjoining PCB etch. Evidently there was some hidden micro corrosion there. And it turned out that other pins were similarly affected.
My solution was to take a thin strand of copper wire (from a multiple stranded jacketed electrical wire) wrap it around the base of said pin and solder it. Then I removed the thin coating of plastic over the etch and soldered the other end of the wire strand to it.
I don't recall exactly how I re-covered the bared etch. Possibly I spread a thin layer of epoxy glue over it. A dab of RTV Silicone rubber might be a better idea.
