General advice for work on R65LS
opus451
Post by opus451 »
Hey All,
I am about to rip down my R60 for a much needed inspection and overhaul.
A pretty good deal on a 1982 R65LS landed in front of me, so I am taking it on for the time being, to stay up.
Are there any better updates to its innards that should be considered?
Any quirks about this model to know about?
For now I was just planning on running it through the basic maintenance points, and roll on. But curious for long term planning.
Thanks in advance!
Opus
Eric "Opus" Carlsen
A Brooklyn native
1976 R60/6
khittner1
Re: General advice for work on R65LS
Post by khittner1 »
There's not much in way of common parts with the rest of the line, so that'd be its primary quirk.
I don't know whether the early Nikasil-bore 650s (all '81-'84 R65s) had the same valve seat/valve recession issues as the '81-'84 1000cc and 800cc "big frame" bikes, or not---a 650 generates less heat, so maybe they didn't. R65 fans will pipe up shortly, I'm sure.
An R65 is just a short stroke version of the larger airheads so while there are many parts differences including narrower valve stems, as far as basic maintenance principles are concerned they are much the same with no big surprises I can think of especially on the engine. One running gear difference is that the front wheel bearings are ball races while the rear wheel has the usual taper roller races.
The LS is a fun bike. In good nick, they may appreciate as they were a wee bit more rare than the other 650's and they have that Hans Muth design. If you're tempted to take off the pointy fairing, take due care and find out how to do it without breaking the connection points. It's very easy to break them. As a long term prospect, buy spares that are specific to them when you see them. You may need them one day, and if not, they'll only appreciate. esp instruments, fairing...
I'm sure you'll find this interesting. Coffee first, and a comfie chair. http://www.advrider.com/forums/showthread.php?t=1045726
opus451
Post by opus451 »
Thanks guys!
I think it will be a fun project.
Eric "Opus" Carlsen
A Brooklyn native
1976 R60/6
opus451
Post by opus451 »
I am listing out the basic things I need to do off the start and thought of these questions:
Can the rear drum brake shoes of a 1976 R60/6 fit the rear drum of the 1982 R65LS?
Do they use the same battery?
Same front and rear tires?
Same air filter?
And is the clutch cable interchangeable?
Eric "Opus" Carlsen
A Brooklyn native
1976 R60/6
khittner1
Post by khittner1 »
It appears that you've never looked at an R65LS. Not much in common with a big-frame /6. The tank emblems are probably interchangeable.
enigmaT120
Post by enigmaT120 »
Clutch cable might work. I think mine is from a /5. Compare the lengths.
Ed Miller
'81 R65
'70 Bonneville
Falls City, OR
enigmaT120
Same rear tires but front is different.
Ed Miller
'81 R65
'70 Bonneville
Falls City, OR
opus451 wrote:I am listing out the basic things I need to do off the start and thought of these questions:
Same air filter?
I know for certain The rear brake shoes on an LS are different (wider ?) from other R65's and I guess that also means different from an R60/6
The LS battery is a smaller and slimmer 18AH type than the usual 30AH batteries used on other Airheads. I think the short wheel base /5 battery was similar.
LS Front wheel is an 18" instead of 19"
Very different air filter. /6 will be the old round type also used on earlier R65's but 81 onwards all R65's changed to the flat filter as did all other airheads.
If the clutch cable is the same length it should fit.
