Relocated the indicators off the headlight ears. That way the fairing I have will now fit.
The bike was getting a bad wobble at around 70km/h. The steering head bearing got a bit of a tighten up. That should help with the wobble.
Fitted some mid 1970s R90/6 handle bar risers to go with the mid 1970s R90/S bars that are fitted. The risers that came with the bike have the bolt heads showing. Yuck. The R90/6 ones are smooth and curvy. Fitted some Col Fosters Signature Series rubber grips. They look old school and cool.
Moved the ignition barrel from were I had it cable tied down under the tank to into the took box that sits under the seat. De-tabbed the frame. Took the sidecover tabs off.
