Many thanks for those helpful suggestions, I was wondering about emptying an aerosol of Mr. Sheen wax over the old girl, and I'd forgotten that tdc is the best resting place.
Both the Berlingo and the trailer will be loaded to the gunnels with the contents of my blacksmithing workshop - so unless I get her to tow them both, the RS will have to wait for next time.
Sunbeem.
Short lay-up.
Re: Short lay-up.
One day more -- one day less.
Re: Short lay-up.
Follow Garnet's advice.Garnet wrote:Make sure the engine is at TDC (OT on the flywheel).
- Manfred
- Location: on a mountain near Gowen, OK; on a 1987 R80RT
Re: Short lay-up.
What is the rationale for this?Garnet wrote:Make sure the engine is at TDC (OT on the flywheel).
There is therefore now no condemnation to them which are in Christ Jesus. (Romans 8:1)
- Moderator
Re: Short lay-up.
Pull up your speedometer cable rubber boot and fill it up with axle grease, cuz if rain water seeps in there while you're gone, by the time you get back, your tranny will be gone.
Re: Short lay-up.
So the cylinder walls are not exposed to the elements, and 3 of the 4 valves are closed.Manfred wrote:What is the rationale for this?Garnet wrote:Make sure the engine is at TDC (OT on the flywheel).
I like Jesus, but I also like Buddha and Mohammad.
Re: Short lay-up.
I prefer to empty the tank completely and leave it open for a few days to dry out (taking care that nothing falls inside).dougie wrote:Fill the fuel tank to the top, and use fuel stabilizer.
That is how I have stored my bike the last 30 years.
Re: Short lay-up.
I too have done that on occasion, but I coated the inside with non-detergent oil as well.justoneoftheguys wrote:I prefer to empty the tank completely and leave it open for a few days to dry out (taking care that nothing falls inside).dougie wrote:Fill the fuel tank to the top, and use fuel stabilizer.
Re: Short lay-up.
As long as HAL doesn't pull the plug!ME 109 wrote:Can cryogenics apply to motorcycles?
