Replacing large left seal in rear drive, '81 R100
Re: Replacing large left seal in rear drive, '81 R100
Wrap the splines with electrical tape or similar to avoid damaging the new seal when installing.
Great idea, thanks!Bamboo812 wrote:Wrap the splines with electrical tape or similar to avoid damaging the new seal when installing.
old seal is out, need to clean now.
A Ranier beer can with the ends cut off fits perfectly over the splines too.
You should remove the cover and replace the gasket. It comes off easily...you thread in 2 screws to pull it off, there are threaded holes provided for this purpose.
Bellingham, WA USA
1975 BMW R90/6
1975 BMW 2002
1971 VW Westfalia
1985 VW Vanagon
1975 BMW R90/6
1975 BMW 2002
1971 VW Westfalia
1985 VW Vanagon
Most first-timers miss the two threaded holes that assist in removing the Cardan cover. 5mm, IIRC.mattcfish wrote:A Ranier beer can with the ends cut off fits perfectly over the splines too.
I've successfully used a trimmed aluminum adult barley beverage can as a seal/spline install tool. The rounded punt/bottom of the can gets the seal's lip properly positioned. Be sure to smooth the cut edge of the can as even a small burr can ruin the seal's fragile lip as you remove the "special tool". Plus, oil to can to aid in a smoother install.
That and don't forget the gasket!
Monte
1981 R65
1983 R65
1978 R100S
1995 Triumph Trophy
1983 R65
1978 R100S
1995 Triumph Trophy
Modern cardan gaskets are thicker now than the original paper thin ones. Replacing it will most likely require re-shimming.
Bamboo812 wrote:Modern cardan gaskets are thicker now than the original paper thin ones. Replacing it will most likely require re-shimming.
Is a modern gasket in a tube out of the question?
https://www.threebond.co.jp/en/technica ... skets.html
Not out of the question; paper gaskets went the way of sword fighting awhile back. In this case though, taking either new or old gasket out of the question still requires re-shimming...SteveD wrote:Bamboo812 wrote:Modern cardan gaskets are thicker now than the original paper thin ones. Replacing it will most likely require re-shimming.
- enigmaT120
Bummer. I'm really good at sword fighting.
But I can't make paper gaskets seal.
Ed Miller
'81 R65
'70 Bonneville
Falls City, OR
'81 R65
'70 Bonneville
Falls City, OR
