I have a Mono final drive apart, whilst washing the crown wheel I lifted it by the Taper Roller Bearing and the cage came off scattering the rollers everywhere!
I've tried but I just can't put the cage back on I came off easy enough - how does it go back together?
Now the very expensive Double Row Angular Contact bearing (3305DA - what does the DA stand for?), it supports the input shaft both radially and axlially but I have what looks like at least 1mm of axial movement that would if I'm correct move the contact patch with the crown wheel in and out. Is this amount of play correct - I ask because the bearing doesn't run rough?
Thanks for your thoughts.
Mono Final Drive bearings
Re: Mono Final Drive bearings
The letters probably have to do with special characteristics of the bearing, like contact angle, slingers, seals and so on. Looked in my bearing book, it just had basic information, Google, however, turned up more information.
Angular contact ball bearings 3305-DA-TVP
main dimensions to DIN 628-3, double row, separable, with split inner ring, contact angle α = 45°
1974 R90/6 built 9/73
1987 BMW K75S
1994 BMW R1100RS
1964 T100SR Triumph
1986 Honda XL600R
1987 BMW K75S
1994 BMW R1100RS
1964 T100SR Triumph
1986 Honda XL600R
You cant do much with that bearing, or your new taper roller bearing, without the proper factory tools, and the guy with the tools will be able to source the correct bearing, so you dont need to know!
Probably "double row, angular contact"
Did you push-pull on the rear wheel before disassembly ?Nourish wrote: ↑Tue Oct 17, 2017 11:21 am ...it supports the input shaft both radially and axially, but I have what looks like at least 1mm of axial movement that would, if I'm correct, move the contact patch with the crown wheel in and out. Is this amount of play correct - I ask because the bearing doesn't run rough?
If I understand you correctly, with that much play then the big ~170mm radial bearing is going bad. The smaller angular contact bearing doesn't give issues, and is cheap (~$35) and very easy to replace. The larger bearing is another story.
You'll need a "bearing separator" able to span a 6-3/4" bearing. You won't need a press, but access to one would help. Install the new bearing first onto the crown wheel. Install the new big oil seal into the case. Then warm the case and install the crown wheel.
A housing gasket is offered, but don't install one unless one came out. Instead use a thin gasket maker compound, such as LocTite 510. Use the exact same shims in the original order and placement.
The 2 halves will mate together and can be drawn up using the 8 housing bolts. Keep rotating the input pinion shaft to insure proper mating of the ring and pinion gear teeth. Then just keep going round and round, adding 1/2 turn to each housing bolt in succession until full torque is achieved.
Don't forget to add new o-rings on the rear brake spindle.
No it's not the 120mm (170mm?) bearing on the crown wheel but the 60x25ish mm on the pinion shaft in the nose of the diff casing where the swinging arm bolts up to.
If it's knackered then getting it off won't be a problem (getting the cash out of my pocket for a new one will be!) But I thought that a bearing of this design wouldn't run this smooth with that much wear.
By just the series number FAG 3305 it is a dual row angular contact bearing. I was checking that series on the internet and they list a wide variety of letters behind the base number which list specific features for the bearing. I would make sure I bought the exact same bearing as it is specifically built for the application.
Found the designation:
DA BALL BEARING, DOUBLE-ROW WITH SPLIT INNER RING. N Now some of the bearings with the DA have other numbers which indicate the carrier style/material, yours should have a steel carrier for the bearings.
1987 BMW K75S
1994 BMW R1100RS
1964 T100SR Triumph
1986 Honda XL600R
1987 BMW K75S
1994 BMW R1100RS
1964 T100SR Triumph
1986 Honda XL600R
