1983 gas cap repair
KeithW
1983 gas cap repair
Post by KeithW »
Has anyone had the gas cap fail & cant get to open. It happened to me yesterday it just spun & did not open. Fix was to pry the lock off and open. Any ideas on how to repair or just buy another one.
Re: 1983 gas cap repair
Snowbum has a section on stuck gas caps...probably something to have looked at before prying the lock open. Look about half way down the page for the "Ratcheting, unscrewing, re-keying" section:
https://bmwmotorcycletech.info/fuel-caps-airheads-K.htm
Take your belt off if you have one and thread it through the handle and pull up with reasonable strength.
At the same time use something with a little weight to it that won't damage the cap. A block of wood or the handle of a large screwdriver.
At the same time as pulling up with the belt, tap the gas cap handle in the direction to undo and you will most likely release the cap.
ME 109.
http://largiader.com/articles/gascap/
https://advrider.com/f/threads/how-to-r ... ap.563553/
Motobins hints wrote:Petrol Cap Jammed? This is not uncommon on older Boxers, the cap spinning round but not unscrewing! It can be removed without damage to paintwork by standing on the footrests, and passing a rope through the filler cap handle; tie it into a loop around your shoulders, and heave - the whole cap will pop out easily.
PAS
Post by PAS »
As a side note, never turn the cap until it ratchets.
Once it's ratshit it's too late. It won't turn! ;)
(sorry, leftover fathers day dads joke)
Saint Matthew of Parkhouse, in the last BMWOA Owner's News column I read, revealed that most late model Euro auto gas caps have the same thread as the screw-in BMW caps. One of his customers replaced his failed BMW moto gas cap ($$$) with a Saab cap for $11!
colmobrien84
Post by colmobrien84 »
Technique described here (Logo cap nondestructive removal) worked a treat for me after failing with few other methods :
Used a wire clothes hanger with 1/2" bend , inserted in small hole under the rubber skirt and twisted gently until it travelled into the cap body and fixed two parts together, after that it screwed out easily.
