While searching internet for H4 LED bulbs most of the information was that the OEM housing was not designed to correctly focus the light emitted by the LED's.
Then I found this product.
https://www.summitracing.com/parts/sum- ... 8kQAvD_BwE
It has a glass lens and DOT approved.
Not affiliated at all with summit racing
Think this would fit in the R100RT headlight bucket?
1982 R100RT Replacing Headlight with LED
Re: 1982 R100RT Replacing Headlight with LED
Not really, Most airheads, Road models anyway, take a ten inch reflector. This on is only seven inches. I suppose it would be possible to arrange some sort of surround to take up the extra space but it certainly isn't plug and play.
10 inch reflector !!!! ????? hmmmRob Frankham wrote: ↑Fri Aug 15, 2025 5:20 am Most airheads, Road models anyway, take a ten inch reflector.
Hmm, I'll have to go and measure one... but I'm sure it's not 7" so the rest of the comment applies...gspd wrote: ↑Fri Aug 15, 2025 2:17 pm10 inch reflector !!!! ????? hmmmRob Frankham wrote: ↑Fri Aug 15, 2025 5:20 am Most airheads, Road models anyway, take a ten inch reflector.
8" except for R45/65's which are smaller
My '73 R75/5's are aprox. 6 1/2". I even matched them up to a 7" and they are smaller.
Tom
Tom
'73 R75/5 SWB
'73 R75/5 LWB
'70 Guzzi Ambo 750
'72 Guzzi Eldo 850
'04 Guzzi California EVT
'07 HD Dyna Street Bob
Tom
'73 R75/5 LWB
'70 Guzzi Ambo 750
'72 Guzzi Eldo 850
Tom
Same size as the R65 headlamp which can be used to upgrade a/5 to a H4 halogen bulb.
Absolutely right 8 inch by the tape measure. Apologies, my memory ain't what it used to be... but a 7inch reflector still won't fit...
- Jeff in W.C.
If you're looking to upgrade your headlight to LED, here's an option. It's a smaller headlamp with an adaptor ring. I have not installed one, so I can't comment on the product other than it exists. http://www.motoelekt.com/lighting.htm
Jeff in W.C.
1988 R100 RT
2018 R1200 GS
1988 R100 RT
2018 R1200 GS
