So after getting down to the bottom of my charging issue (thanks a ton!) I Noticed a little sloppy handling in the corners and control issues at low speeds that I attributed to the notched steering bearings. Wanting to procrastinate on pulling the front end apart as long as possible, I made my way down to DMV to get tags and try to legalize my new bike.
On the way there I was leaning through a decent right hand corner in town when the rear wheel skipped to the left a few inches almost causing me to go down. I pulled over onto the sidewalk, hosed out my boots and grabbed the rear wheel with the bike on the centre stand and clack a clacka clack... shot rear wheel bearing. One of the cages had exploded. OK, to be expected with a bike that sat for years plus I was gonna do ém soon anyways, so off I go to the local (retail) bearing house, McGuire. After the counter person informed me they have no Timken, SKF or FAG bearings, he produced (4) Axis brand bearings which are the private label for McGuire. I thought what the hell, ISO standards are in place for a reason and no matter where they are made, they should be fine. Later I found the origin tag in each bearing box (China) the bearings were only marked with size on the inner race.
I measured out the assemblies, took a couple thou off the wedding ring spacer for the rear, packed them with the good grease and rode the bike home. Felt great. Still notchy in the head, but no more shorts-greasing moments in public. 2 days later I pulled the wheels off to put new S11 Spitfires on her and wiped the grease oozing past the front seal off with my finger and noticed tiny metal flakes in the grease, so out come the wheel bearings again, and the outer races show insane scoring evenly around the wear surface with no heat blueing whatsoever. It's like the metal had no hardness at all. Kind of scary. I took them back to McGuire and after an hour of the counter guy pissing in my ear about installation errors on my part the manager refunded my money. I then went through a wholesaler and sourced 70's production TImkens made in France in the wax-board boxes, installed them and put 500 Trouble free miles on them. SO: Don't buy Chinese bearings. But you already knew that
During the 500 trouble free miles up the Isle of Vashon TT and back, I had a horrifying tank slap from the worn steering bearings, heavy wind & ruts and had to stop at a friends house along the way to replace them in his driveway. Luckily he had the race extractor tool, and 2 guys I was riding with went to the stealership and fetched new bearings. By the time they returned from Fife, WA the bike was apart and ready for the new parts. Now she handles like a dream and is as safe as she can be in I-5 traffic. What a week! If anything I am more familiar with this bike now.
Happy riding!
