R1200RT rear drive oil
Re: R1200RT rear drive oil
More than 100 times !? How often do you do it?
I was a lead master tec at Touring sport for 16 years.... done it a few times..
I see. So, obviously, this is a valid maintenance procedure in your opinion or should the final drive be dropped and rotated per previous suggestions even if no other work is being done to the bike?
I believe the answer clearly is: yes.CVA-42 wrote:I see. So, obviously, this is a valid maintenance procedure in your opinion or should the final drive be dropped and rotated per previous suggestions even if no other work is being done to the bike?
Is that how you did the 600 mile break-in service?macdaddy wrote:I was a lead master tec at Touring sport for 16 years.... done it a few times..
you need to try it. If you have a good evac pump it works VERY well. BUT not for the newer bikes w/ no "fill" plug. there is more than one way to skin a cat....
Again, is this a technique that you would use during a 600 mile break-in service?macdaddy wrote:you need to try it. If you have a good evac pump it works VERY well. BUT not for the newer bikes w/ no "fill" plug. there is more than one way to skin a cat....
I agree that there is often more than one way to do a job and I'm all for techniques that can help make a job quicker or more efficient...if there aren't any downsides. We are going to have to agree to disagree on whether this subject has downsides, or not. I do know for 100% certain that the fellows in New Jersey would raise more than a few eyebrows if they discovered that a failed final drive was maintained this way...yes, they would probably still pay for it under warranty, but they would not be happy.
My background (all, thankfully, in the past): I have done a few dozen fluid changes on the "no drain" final drives (not that many, but enough to realize that it's a pretty easy procedure)...I've "overseen" (as Service Manager) well over 1000 fluid changes on them (probably a few thousand)...and, I've submitted quite a few warranty claims on the late model final drives (mostly bad seals...very few outright bearing failures). Oh, and I have a very good evac pump...I use it mostly for brake fluid. I had some really good and efficient techs and I had a few really lazy techs...not a single one of them sucked the fluid out the top.
