/6 Camshaft gear installation question
Re: /6 Camshaft gear installation question
I like to freeze the steel and heat the aluminum, then work very fast.
For example, the factory didn't heat the hubs to slide in the wheel bearing stacks. Instead, they just froze the stack in a box full of dry ice. Even with the hub at ambient temps, the stack would just fall in.
