exterior color match siebenrock to BMW head?
Re: exterior color match siebenrock to BMW head?
SteveD wrote:Here's a response re: the short term look ...from George Strong in the UK. bmbikes forum.
Barrel fins seem OK with the silver leaf rub'n'buff even after prolonged heat - doesn't look any different after about 500 miles. Same with base of barrel and crankcase ... I'm still on the first tube after covering everything alloy, with a spare on the shelf.
Unfortunately, that doesn't tell us anything about the higher heat application of the heads. Course, if jj tries it, they we can ALL find out! :mrgreen:
My guess is that not many will try it on the heads, or the barrels, as it'd be a tedious application rubbing it in down amongst the fins. I was surprised to read someone had had a go at the barrels. I think he used a tooth brush to apply it. I doubt I'd have the patience.
jjwithers
Post by jjwithers »
Just an update. I had the heads vapor blasted and i think they got pretty close to matching the Siebenrock cylinders. It appears to me the cylinders are painted a bit. I wish Siebenrock disclosed more information (in English) about their materials.
check out the vapor work:
http://beemersandbits.com/2012/05/vapor-blasted-heads/
www.beemersandbits.com
'66 R60/2
'72 BMW 2002
Instagram - jj_withers
They look spectacular, and better than the new barrels, but near enough for it to look great.
