MOT passed today
Re: MOT passed today
montmil wrote:Water can easily enter the gearbox if the rubber speedo boot is cracked, aged and split. Hey... That sounds like a description of my ex-wife. Thank God and Greyhound she's gone... :lol:
My guess is that it is a description of yourself as well. 8-)
Deleted User 287
Post by Deleted User 287 »
Monte keeps his rubber parts soft and supple with free coffee from the neighborhood funeral parlor. ;)
montmil
Post by montmil »
:lol: Quoting Mary Tyler Moore here... "Oh, Rob".
That Bengt Phorqs guy over on the R65 forum is a blabbermouth!
1981 R65
1983 R65
1978 R100S
1995 Triumph Trophy
sterob
Post by sterob »
Garnet wrote:
derek1922 wrote:When i tipped the gearbox up during the restoration there appeared to be quite a bit of water in it,I got as much as possible out and refilled with new oil,maybe I'll drop the oil and refill with fresh stuff again.
Thanks for your thoughts.
Good plan, not a good place for H2O.
As far as buzzing of the bars, spend some more time balancing carbs. The best part of an airhead is how smooth it is on the highway. :D
My thoughts as well. You will be amazed at the changes with even just a small carb balance error corrected.
Well done on the MOT pass.
derek1922
Post by derek1922 »
Thanks guys as usual,never balanced carbs before so I'll be learning something new :D
Deleted User 287
Does anyone have a picture of gspd's modified throttle control (two cables/no splitter) with a cable adjuster mounted on it for just one of the throttle cables?
In this way, Derek, he was able to make small adjustments while going down the road.
Duane suggests the same thing using the left carb's adjuster - but that requires taking your eyes off the road longer and having your hand way down there.
It probably was no big deal when Duane was riding, as there were so few other vehicles sharing the roadway back then... ;)
"It did a bit of head shaking when I was taking a roundabout at speed but I never felt the bike would lose control."
That isn't normal, or safe. Since you are new to this boxer stuff, be warned, that can get very dangerous very quickly. If it isn't stable, then it is dangerous and you won't have time or skill to get out of it.
I am surprised that you got this many comments and nobody thought to warn you about the instability.
khittner1
Post by khittner1 »
+1; check/have your headset bearings' torque checked. It shouldn't wobble in curves.
derek1922
Post by derek1922 »
I feel silly (again) but it always helps to check your tyre pressures-yep,just needed air in the tyres,oops!
derek1922
Post by derek1922 »
checked the tyre pressures,20 psi in the front tyre and only 15 psi in the rear,that'll get the bike squirming on the corners,I'll need to get a couple of right angle adapters for the tyre valve stems as the air hose at the petrol station can't get in(as usual) to the valve,not enough room.
