clubman handlebars
caterwaulinguist
clubman handlebars
Post by caterwaulinguist »
I'd like to put some clubmans on my /5 Toaster, but I'm a little uncertain about sizes and styles. Sounds like sanding down 7/8" bars is the norm. Am I right? Anyone got a brand or model they'd recommend?
Unclviny
Re: clubman handlebars
Post by Unclviny »
Will flipping your 'bars upside-down do it?
I am running R90S 'bars on my /5 and I am glad that they are not any lower.
Vince
1973-1/2 BMW R75/5 (LWB)
1971 Norton Commando
1952 Triumph TRW
1936 BMW R2
caterwaulinguist
Not a bad idea -- I'll have to check it out. I bet when they're that low they'll crowd the tank too much. I think you need the clubman shape to move them forward while also dropping them.
vanzen
Post by vanzen »
Flipping stock bars often results in interference
with the upper 3-tree or fork caps.
Finding 22mm clubmans may be impossible.
However, the measured OD of 7/8" bars varies significantly.
Very often the difference will be the thickness of the chrome.
Fitting 22mm controls onto 7/8" bars
often involves some work
but is not so difficult.
Either the OD of the bar can be reduced
or the ID of controls enlarged.
I prefer to work the bars using sanding papers.
A hint: get (black) powdercoated bars not chrome -
Easier work.
Also be sure to buy bars that are wide enough
to clear the forks.
caterwaulinguist
vanzen wrote: I prefer to work the bars using sanding papers.
Easier work.
to clear the forks.
Great tips -- thanks much. If the jpeg link below works, can you answer one other question for me? It seems there are two styles, those that don't drop so much as just set the grips forward (the Clearance Clubmans in the pic) and those that drop them considerably (like the three behind the Clearance). Have you found either style to be preferable over the other?
http://beemersandbits.com/wp-content/up ... rs2lr1.jpg
Post by Garnet »
vanzen
Post by vanzen »
Your physical "dimensions"
and desired ergonomic preferences
define the answer.
If clubmans fit correctly,
i.e. clear the forks and fuel tank,
there is a bit of adjustment possible .
The drop and reach need to fit you.
caterwaulinguist
Fair enough. Thanks.
jjwithers
Post by jjwithers »
I posted a link to Clubmans on my site:
http://beemersandbits.com/2011/06/clubman-handlebars/
I found that i really liked the reach of my set of bars on one bike. I didn't want the same set of handlebars but i wanted the same reach and found a set of drag bars that had the a similar reach.
They are all 7/8" bars though. I got a big drill bit (probably 7/8") and put it in my drill press and pressed the handlebar clamps up to the bit until it was ground to a 7/8 size. I had to dremel out the inside of my controls to fit the bars as well.
-Josh
www.beemersandbits.com
'66 R60/2
'72 BMW 2002
Instagram - jj_withers
caterwaulinguist
Much obliged!
