Gas / Fuel Cap issue '77 R100/7
JeramyN
Post by JeramyN »
My gas cap rattles like CRAZY when i ride. It seals properly through the threaded part into tank but it seems like the two pieces, top handle/flat part and threaded par, are not snug to each other as in they move independently form one another. Is there a way to tighten the two to each other? Otherwise i'm about to JB weld that thing so it stops... It drives me crazy. would hate to do that.
The piece is very clean and the gaskets are like new. Lock even works...
Thanks in advance,
J
dwerbil
Moderator
Re: Gas / Fuel Cap issue
Post by dwerbil »
Maybe you should identify what kind/year of machinery you're talking about?
Click for pics
Randy in Round Rock
Maybe this one?
viewtopic.php?f=1&t=6699&p=78225#p78225
JeramyN
Post by JeramyN »
Sorry, it's a 1977 R/100. I always assume that is listed w/ my name.
is there a way to tighten these two pieces together?
Re: Gas / Fuel Cap issue '77 R100/7
It's a press fit. Maybe crimp them together a bit more. Click on the thumbs.
You can control the movement by connecting the holes between the pieces, to prevent movement. A short piece of wire...maybe solder.
I wouldn't lock the cap until you've fixed this. Actually, I never lock it anyhow.You'll be back asking how to solve a different problem otherwise.
You can make a signature where your bike details will be seen with each of your posts.
