I'm curious as to what other people see with regard to diaphragm life in years, not miles before you see degradation.
Then what type degradation do you see - stretched diaphragm, hole, tear?
In your reply please tell us what % ethanol is in your typical fuel too.
What Life Do You Get From Your Diaphragms?
Re: What Life Do You Get From Your Diaphragms?
I do mine about every 5 years. 98 RON fuel
What's ethanol?
What's ethanol?
I appear to be getting about 3 years before diaphragms get stretched out making cable balancing for 3500 rpm next to impossible for repeatability.
I typically run what's available near me, 93 octane ,(RON+MON)/2, with 10% ethanol....that's what we have near me and I'm in the Chicago fuel market area.
Three to 5 years depending on usage.
When the acceleration goes sluggish, I figure it's TIME to replace.
This is before you see a tear or other obvious damage.
Jean
Do you find your diaphragms to be stretched or distorted when you change them out? That's what I'm seeing even though acceleration wasn't sluggish I was getting vibrations from imbalance. Never have had a tear or pin hole.
I've seen the same thing on a lawn mower with Briggs & Stratton engine with a diaphragm...had to change it once per year when it started running like crap I knew it was time. I blamed it on ethanol vs. the diaphragm material.
I wonder if theDelrin diaphragms as sold by Motobins would be a better material
Sorry, its Hydrin, not Delrin
I wonder if the
I changed mine after 30 years (preventative maintenance....), and they were in good condition! I live in a dry and non-corrosive climate, and no ethanol.
- Ken in Oklahoma
jtoml wrote:I changed mine after 30 years (preventative maintenance....), and they were in good condition! I live in a dry and non-corrosive climate, and no ethanol.
And I have never had to change a diaphragm that wasn't years old.
Ray, stretched could describe them. They seem a bit floppy compared to the new ones.
I've used the term "dead", before, to describe them. The new ones seem to be stiffer...
- Zombie Master
She got pregnant. I don't trust them.
ZM, in your case 'human' would have been a more appropriate answer to the op's question.Zombie Master wrote:She got pregnant. I don't trust them.
