For comparison, here's the right (good side):
Here's where I am in my investigation which was so far mainly comparing left and right "settings":
Compression: equal on both, measure with carbs off (9.5 or so)
diaphragms: ok, no rips or holes
floarbowl level: equal, float bowl parallel to carb body method
Needles: 1st from top, tried 2nd (stock) with same result
Needle yets: 2.68, "goodplug" O-ring was slightly ruptured
Confirmed position of needle in the jet - same height (measured from below with main jet removed)
Main jet: 160 (have not confirmed whether they are what they say they are)
idle mixture screw: new with new orings and springs (adjusted, about 1 and 1/8 rev out for both), bore is clean and free, o-rings seal as they should
idle jet: 45
Gas mileage: about 37-40mpg mixed
Plugs: new BP7ES (have not confirmed spark quality yet)
Coils: Dyna dual (green), about 4-5yrs old (have not confirmed spark quality yet)
Ignition: points with Dyna booster ( (have not confirmed spark quality yet)
Valve play: 0.06/0.08
Rockeram axial play: close the zero, but freely moving
Other observations:
downpipe temps: the "bad" side seems to run hotter (I always thought rich runs cold?), measured about 30F higher with wireless IR thermometer
when removing the idle mxture screws they are both dripping wet with gas (that is maybe normal)
I am scratching my head:
All "enrichening" factor have been looked at except for reducing the jet needle or trying a 2.64 and play wirth needle settings again. Both carbs were always different, but it seemed to have deteriorated.
I can also swap the carbs and see if it is indeed carb related. I was hpoing I would not have to do that 'cause somebody comes up with a magic trick!
I can also clean the carbs again although they seem to be squeaky clean and I run them with (VW) in-line paper filters from day 1.
Ideas anybody?
Thanks, Stephen
