What's the Preferred Fuel Line Crossover Method?
captmako
Post by captmako »
I'd like to run tees off my petcocks to have mutual fuel lines to both carbs. I have seen tees and lines run behind the airbox; over the top of starter cover; through starter cover...... :?: Is there a preferred method for running crossovers?
chasbmw
Re: What's the Preferred Fuel Line Crossover Method?
Post by chasbmw »
Why not use the BMW method?
Charles
1975 R90/6
Jeff in W.C.
Post by Jeff in W.C. »
chasbmw wrote:Why not use the BMW method?
And what would that be? :mrgreen:
Not that I'm an expert, but almost every bike I've seen (airhead that is) has it running behind the airbox.
Jeff in W.C.
1988 R100 RT
2018 R1200 GS
The usual BMW way is to run the crossover fuel line between the lower front of the airbox and the gearbox.
http://www.advrider.com/forums/showthread.php?t=703807
vanzen
Post by vanzen »
I've always preferred the "X" fittings
as used by Moto Guzzi
but BMW's (as stock) "H" routing
is well suited to the powerplant's geography.
I run mine around the back of the clamshell airbox. It's just easier.
BMW made holes in the airbox just for the fuel lines. By far the most important aspect is to make sure that one has enough fool flow to insure that a low point in the line isn't clogged up.
Duane Ausherman wrote: By far the most important aspect is to make sure that one has enough fool flow
I got that in spades.
Rather. :roll:
jagarra
Post by jagarra »
MY crossover line looks to be made of different material, has no cloth covering. What is used as a replacement?
1974 R90/6 built 9/73
1987 BMW K75S
1994 BMW R1100RS
1964 T100SR Triumph
1986 Honda XL600R
