I woke early today...
Re: I woke early today...
It's all about the process. No reason to hurry. Image
Deleted User 61
Post by Deleted User 61 »
Their website says they use high temp polyester tapes and silicone plugs. The tape may be good enough to protect my steering head race faces. I think I tossed the old races, already... :(
http://www.indypowdercoating.com/index.php?P=services
Rob, if you send all your parts to GSPD, there will be a finished bike in your mailbox tomorrow night!
vanzen
Post by vanzen »
R65 Rob wrote:Their website says they use high temp polyester tapes and silicone plugs. The tape may be good enough to protect my steering head race faces. I think I tossed the old races, already... :(
Have you been to their shop, Rob ?
Pay close attention to the product that is ready to go out the door –
look for smoothness of application, bare spots, powder in threaded areas, drips, and the like.
Also try to check out the prep procedures – these will make or break a coating job !
Good luck ! Getting fresh powdered parts back will be like the thrill of a kid on Christmas morning !
Steve in Golden
Post by Steve in Golden »
If you do, you might want to get in touch with gspd and discuss his technique for using a drill to wind the speedo to rack up impressive numbers of miles. Well kilometers in gspd's case.
Max Headroom wrote:
R65 Rob wrote:Does this mean I have to scrub my engine, transmission and final drive cases to match the splendor of the frame and tank?
And then try and keep it that way?
Hmmm...
It could be worse than you realise, Rob. Before long, you'll buy a trailer so that you can display the bike at shows . . . . :twisted:
It's all downhill from here. Except for the uphill bits.
R65 Rob wrote:The powder coater offers two blacks in their "stock" colors, a Satin Black and Gloss Black.
I would think our frames are more of a semi-flat?
Gloss will eventually turn into semi-gloss if it is wiped down with dirty shop rags often enough.
Deleted User 61
Steve in Golden wrote:If you do, you might want to get in touch with gspd and discuss his technique for using a drill to wind the speedo to rack up impressive numbers of miles. Well kilometers in gspd's case.
Actually this incarnation will be a "no-odo", at least in mechanical terms.
The speedometer got smashed up pretty good, and since I don't really use it since I mounted the GPS (which was flown free of the crash and survived, fine!) I have decided to eliminate the unit altogether. A favorite machinist made this up for me, after I saw Stephens:
I am hoping to "rise above" high mileage bragging... :roll:
vanzen
capping the speedo
Post by vanzen »
Ummmm. Hope that cap is vented ..
Deleted User 61
You mean besides the vent in the ground strap screw?
