How the heck do you remove the bearing from a R100R wheel
Re: How the heck do you remove the bearing from a R100R whee
My Oct 78 build snowflakes have the steel inserts.
barryh wrote:My Oct 78 build snowflakes have the steel inserts.
My September 81 flakes don't.
Dan in IL
Post by Dan in IL »
Duane I really don’t know where you get your information from? Over the years I’ve replaced many roller bearings from aluminum housings without using heat. A recent one was in a self-cleaning oil filter on a 3000 horsepower diesel. I can’t remember ever tearing one up. Most of the time they’re just barely less than slip fit. I don’t know why, I don’t design them, I just fix them
ME 109, I wonder if your flakes could have a thin layer of the aluminum casting hiding the steel, kind of like I talked about on my R/H side of the front wheel on my '78 R100S. If that "flaked bondo like" coating had been integral, then I wouldn't have seen parts of the darker oxidized steel insert, or so it would seem.
I don't really "need" for the snowflakes to have the steel insert or not. Or like the Oklahoma locals say, "I don't have a dog in this fight".
No Ken.
Ugly, innit!
ME 109, what is that brown stuff at the back end?
Duane Ausherman wrote:ME 109, what is that brown stuff at the back end?
That brown stuff? Why that's just rust from the metal insert in my sept 81 flake. :oops:
Gotta go, someone's at the front door.
Well I'm a monkeys........ :? metal worker and all...
I've never put a magnet near my old rear flake. I did today after Duane's prompt.
Son of a..........it is impossible to see any join between the sleeve and ally hub. The colours are identical.
The new/second hand rear flake that I got off German ebay recently, has a sleeve that is most clearly visible.
I was beginning to think I was special too. :roll:
For a minute I thought we had a rare case of aluminum rust!!
It could have been worse I spose.
Duane could have said rear end.
