How the heck do you remove the bearing from a R100R wheel
DonW
Post by DonW »
Hi, Just got a R100R front wheel. Sealed bearings. Want to remove so I can clean the filthy wheel. how do you remove them? There's no "lip" to knock them out from the other side.
Thanks
Don
'83 R80ST
'92 R100GS
'04 R1150RTP
Re: How the heck do you remove the bearing from a R100R whee
Check the bottom of Snowbum's page:
http://bmwmotorcycletech.info/section4.htm
Do not skip the heating of the hub, or you may ruin the hub.
Snowbum mentions "cold pressing" of the bearings and warns against it. I wonder what he is referring to in this aspect. The factory never heated a hub. They cool the bearing set in dry ice and it falls into place. I wonder if someone called that "cold pressing?"
Never try to put a bearing in place on one of those older BMW wheels with everything at ambient temperature. Your wallet will be sorry.
It doesn't really matter how one gets the temperature difference, heating or cooling. I not only heat up the hub, but put the bearings in the freezer for 15-20 minutes. They really do fall into place then.
Bob Distelcamp
Post by Bob Distelcamp »
If you can not get dry ice try this... get some crushed ice place it in a small steel pot, with bearing pour
a small amount of acetone over the ice. that will give you some shrinkage.
Bob Distelcamp
PS DO NOT USE YOUR WIFE'S GOOD POT. go to good will for one.
DonW
Post by DonW »
I get heating and cooling to get the bearing in. What I wonder is, is there a trick for REMOVING IT? I'll heat the hub, but do I need to buy or borrow a blind hole bearing remover?
Don
'83 R80ST
'92 R100GS
'04 R1150RTP
I'm not familiar with the wheel Don so I can't help/hinder.
Got a pic?
I guess I can hinder actually. :mrgreen:
Both my manuals say DO not heat the hub with a torch. Use a HOT-PLATE,
Not any pictures but I'd guess after the hub is hot, a blind bearing removal tool would be needed.
The bearing is not likely to fall out as assembly not only requires heating the hub to 100C but also freezing the bearing (in your freezer!)
Do not handle the bearing with bare fingers.
Either time!!
PS. Do you know if it a TYPE ! or a TYPE 2 wheel? procedure is different for each of these.
chasbmw
Post by chasbmw »
An electric paint stripping gun, seems to work well
Charles
Jean wrote:Both my manuals say DO not heat the hub with a torch. Use a HOT-PLATE,
Either time!!
They say don't use a torch as most don't know to keep moving the heat around so as to not over heat one area. I like mapp gas, but sometimes use acetylene.
We had a puller that would gently and evenly pull on the bearing as the hub was hot.
Dan in IL
Post by Dan in IL »
I changed the front wheel bearings in my ‘88 RT a few years ago. I borrowed a blind hole bearing puller from Autozone. As I remember, the bearing puller didn’t exactly fit but I did manage to get them out. The new ones just tapped into place, didn’t use any heat to get them in or out.
It’s a simple swap. There’s no magic, and it’s not rocket surgery.
