Long over due for and update...
Many weeks have been spent unable to do much of anything, so as predicted progress is slow... none the less, I am still making forward steps.
Another new piece arrived -
The most important information I have read about spray painting, has nothing to do with painting... its all about the preparation.
My process for the steel was a little more involved than the alloy due to surface rust pits etc.
First was to use a bench grinder with wire brush, then hand grinder /wire brush tight spots, then hand brush / dremel the super tight spots.
Triple hand application of rust converter/prohibitive, followed by dewax/degrease for any final surface contaminants & finger prints ... then 3 coats of 2pac surface primer/filler.
The following day (or 2 or 8) each piece then was hand sanded with 240g, 400g or foam sanding pad as required.
All pieces were then resprayed with another 3 coats of primer/filler and hand sanded again.
The main frame, sub frame & swing arm were the given a further 3 coats of p/f & wet hand sanded with 600g.
Now were are looking smoooooth...
Finally, the top 3 coats of black...
All steel frame, sub frame, swing arm, foot pegs, fairing brackets, battery box, side & centre stand to name a few... are now finished... except 1 final step (against the purist's & predominately as an extra stone & chip protection barrier) I will spray a final 3 coats of clear to the main frame, sub frame, swing arm & fork sliders.
When that is done I only need to attend to a new uni & reassembly of swing arm and I will be at the stage to assemble a completely restored rolling chassis & brakes.
How ever, I choose not to assemble just yet because of space, weather protection & these bloody pesky mud wasps wanting to build in every nook & cranny... it is easier at the moment to simply keep adding to boxes of "completed" components.
Next stage - Tank restoring / prep inside & out, seat cowling & fibre glass repairs. Starting with the need for a new insert for the lost one on a lower fairing piece -
... needed repair of missing chunk from r/h upper fairing-
... and a couple other minor things like a broken mounting tab I have no pics for.
... then, yep... you guessed it... back to more sanding before starting the whole primer/filler/sanding scenario again.
Then the super fun part ive been thinking about & planning for ages... Betsy's final dress colours
Total resto cost to date is about $3400 which includes all painting materials, new seat, stanchions, crank shaft, top triple clamp, brake m/c & caliper fitout kits, chassis/wheel/ steering bearings seals cups springs, fairing clips & pins, foot peg rubbers... to name a few.
On the mechanical side, I have now obtained about 40% of required engine parts and am planning & budgeting the final $3500 needed for parts inc head work, u/g charging system, engine assembly & final tuning labour... then rego !
So at this stage it looks like a final bill of around the $7k mark.
Still aiming to take Betsy for a ride on my 50th in October
