75/5 front wheel bearing removal.
I am having a hard time removing the cover over the bearing on the brake side of my 1970 R75/5 front wheel, I tried tapping it out with a drift from the opposite side and also tried unscrewing the cap with no luck. I even tried heating the cap and driving it from the opposite side, no luck. Any good ideas of what I’m doing wrong????
Re: 75/5 front wheel bearing removal.
Duane Ausherman has the most detail info on the /5 wheel bearings here:
https://w6rec.com/the-5-wheel-bearings/
Thanks for the info, that is a n excellent resource!!!
Well, that did it got it apart!!! Never have I seen a wheel bearing designed like that!
Vincents had taper rollers too - and they actually gave you a figure, two thou, to preload them to.
