There are times when I would like to disconnect my clock. The battery I have replaced, cost twice what the replacement starter did. Disconnecting the clock requires disconnecting the battery ground, or pulling the positive connector off the clock.
Both methods are inconvenient. As a North American, any inconvenience is unacceptable.
I've actually got some sparking, re-installing the positive lead. This type of behavior would be frowned upon in der fatherland.
I remember seeing quick ground disconnects for sale at BMW ralleys in the distant past, but I haven't seen those in decades. Not sure if they were any good.
I'm thinking, a small in-line (mounted on the positive lead wire) interrupter type switch would be nice, but i can't seem to find one that is light enough (or waterproof) to create a sanitary installation.
Any thoughts? Please don't let my problem delay you from getting your vaccine shot.
