Hi All,
I ignored my better judgement and purchased this airhead. I don’t know squat. Who wants to go first? Thanks!
https://www.instagram.com/p/COF_ntwMvAX ... 965ka47pgm
Newbie just bought 74 R75/6
Re: Newbie just bought 74 R75/6
Looks a nice clean bike. Probably refurbished not so long ago by the look of it. The fairing isn't original but that's not an issue, it looks like a R90s fairing or something similar.
What do you need to know.
Thanks, Rob. Apparently, it sat for some time. I don’t know how long though. The person I purchased from only had the bike for 2 weeks and didn’t know much. I rode it home about 60 miles. It seems there is some knock from the engine and the front brake is squeaky while moving but not necessarily when in use. Maybe it’s the forks. Since I know absolutely nothing, where should I start so that I don’t break it.
My approach would be to replace all fluids ie. Engine Oil, Gearbox oil, driveshaft oil (in the right side of the swing arm),final drive oil, fork Oil, brake fluid & etc. Then carry out a full service checking valve clearances, ignition timing etc. I would dismantle the brakes and replace pads if necessary, replacing them with anti squeal paste. Check the rear brake. As far as the carbs are concerned, I would remove and clean the float bowls but I think I'd leave adjusting them, unless there were slow running problems, until I'd run the bike a few miles to see what running issues there are (or aren't). After that, it would depend what issues were found during the service and initial running.
If you haven't got a manual get one for oils, torques and other settings and last, but not least, don't listen to too many scare stories. Airheads are basically very sound and, as a general rule, require only regular maintenance...
Thanks for the info, Rob, much appreciated. I’ll start with the fluids and google/youtube.
Re: Newbie question
Have you checked for a bent frame?BMW74R75-6 wrote: ↑Sun Apr 25, 2021 11:45 am Hi All,
If you stand on the foot pegs and look down at the engine, do your left and right cylinders line up perfectly?
Re: Newbie question
gspd wrote: ↑Mon May 03, 2021 1:09 pmHave you checked for a bent frame?BMW74R75-6 wrote: ↑Sun Apr 25, 2021 11:45 am Hi All,
If you stand on the foot pegs and look down at the engine, do your left and right cylinders line up perfectly?![]()
Re: Newbie question
Okay now I'm curious. Should they?gspd wrote: ↑Mon May 03, 2021 1:09 pmHave you checked for a bent frame?BMW74R75-6 wrote: ↑Sun Apr 25, 2021 11:45 am Hi All,
Re: Newbie question
The cylinders have to be off set. GSPD is just being the "mechanic from hell." But do pay attention to what he says. He knows his shit.kmisterk wrote: ↑Tue May 04, 2021 10:21 pmOkay now I'm curious. Should they?gspd wrote: ↑Mon May 03, 2021 1:09 pmHave you checked for a bent frame?BMW74R75-6 wrote: ↑Sun Apr 25, 2021 11:45 am Hi All,
Our connecting rods are side-by-side on the crank, so yes, offset is normal.
Some V-twins have a "knife & fork" con-rod big ends, which allow the cylinders to be inline.
