Mounting a RS fairing bracket
Post by Deleted User 62 »
OK, I know I asked this question a couple of forums ago, but I can't find a reference to it in the archives. I'm mounting a aftermarket fairing on my '74 R90/6 using a stock BMW RS fairing bracket. Is the mounted centered top to bottom on the headstock tube? Any photos of where the bracket mounts and clues as to cable routing would be much appreciated. Thanks!
Re: Mounting a RS fairing bracket
How about this?
Oops, it's 5am here, that photo doesn't help does it.
Yep, thanks Jeff, that's the photo I was thinking of! Looks like it's mounted a bit high of center. Which cable is that coming through the hole ?
Hope this helps Tim.
The bracket is removed (S fairing) but this shows the bolts.
I will take some measurements shortly.
dougie wrote:Hope this helps Tim.
Doug, could you measure from the top of the fork stop to the center of the bottom mounting bolt? I have a feeling it's the same location as the bottom rivet of the ID plate...
My frame is an '87 Monolever - don't know if that makes a difference.
I could not get all the way in with either a ruler or caliper so used a school compass then measured off the compass.
1) Bottom of steering head to centre of lower bolt is 61mm (or close to it).
2) Top of steering stop to centre of lower bolt is 38mm (or close to it).
dougie wrote:My frame is an '87 Monolever - don't know if that makes a difference.
Thanks for the effort, Doug, but I am noticing the bottom cup that holds the bearing race on the Monolever is a different design than the /6. Anyone else care to take a measurement like in the second photo Doug posted?
Tim Shepherd wrote:Yep, thanks Jeff, that's the photo I was thinking of! Looks like it's mounted a bit high of center. Which cable is that coming through the hole ?
That's the speedo cable man.
I'm not sure if it's going up through the hole or down through it :?
