Early vs Late model alternator rotors
My friend with the 1990 GS has discovered his alternator rotor is kaput. At $450 plus from BMW he is looking for alternative alternators. My question is this: Hucky sells rotors for /7 for $160. Is this a direct swap, or would the stator ring etc need to be replaced as well? Does a "17a" (MaxBMW) need a matching stator to work? Thanks in advance!
Re: Early vs Late model alternator rotors
Try motorrad electrik...they have new rotors for $124.95 and remanufactured ones for $90.00 USD.
http://www.motoelekt.com/charging.htm
I put a reman one on my 91 GS 3 years ago and running great. No problems. Rick's a great guy to deal with too.
Think rotor from /7 should work on the 90 GS..think both models are the 280watt setup. No need to swap out stator should work with new 280w rotor.
Ah Thanks, I should have thought of Motoelekt.com
And also look at Euromoto Electric http://www.euromotoelectrics.com/produc ... lt-mg+.htm sells everything you need for a re-new or just for spares.
Motobins also has the choice between the expensive and identical function (they claim) cheap rotor.
Don't have anything bad to say about Motobins, but I KNOW that Motorrad Elektrik gives very good service and support.SteveD wrote:Motobins also has the choice between the expensive and identical function (they claim) cheap rotor.
I've used Motobins over the past few years along with a few of my riding mates. We try and combine orders for one shipment.. Never been disappointed with selection, availability, prices or deliveries. We get most orders 4-6 days from England to Canada.
I ordered a particular part for my R75/6...within an hour of placing order I had an e-mail questioning my selection (you have to give model info/year/even vin#) so they make sure you are ordering the right part. Amazing, I had ordered a SS brake line for my 74 R75/6 but it was incorrect...they verified by e-mail and sent me the correct one!
I can get parts faster from England than the US even though I', only 4 hrs north of the border.
- Ken in Oklahoma
Major Softie wrote:Don't have anything bad to say about Motobins, but I KNOW that Motorrad Elektrik gives very good service and support.SteveD wrote:Motobins also has the choice between the expensive and identical function (they claim) cheap rotor.
Me too. I remember looking on (metaphorically) as Veg fought his intermittent charging issue on his Batbike. I was impressed then, as I have been with all of the "testimonials" I've heard about Rick.
Rick will have it all over Motobins for technical support, but from where I sit here in Oz, 'bins provide an excellent service with a huge inventory.
Rick's good on delivery, so it will usually get down to the total cost for like articles.
eg
Rotor OZ$127 + post from Rick.
Rotor OZ$78 + post from 'bins.
eg
WOW...that is a deal for $149.00 if I read it right...you get rotor, oil seal, voltage reg, diode board and brushes in one package!!Garnet wrote:And also look at Euromoto Electric http://www.euromotoelectrics.com/produc ... lt-mg+.htm sells everything you need for a re-new or just for spares.
It would be worth it to have sitting on the shelf just for those days``....
