me shortly after I had bought my R80 in July.
I was still in Central Australia when I purchased the bike, only seen in photos
from the mate of a mate.
My mate handled the cheque and had the bike delivered and stored under his house
until we got home and went up in early October and trailered it the 320km home.
Did all the paperwork had the rego transferred insurance arranged etc.
It was suggested that I could catch a bus up and ride it home but I didn't fortunately.
It was still in the PO's name no insurance or bike gear.
I was coming home from visiting my aged parents one Sunday morning when
I felt the back was "squirmy" aha I thought "Flat tyre".
Stopped had a look - Tyre not flat.
Took off again, stopped at lights rode off- something not right here.
Pulled off the road again, had a closer look - Rear wheel bolts backing out.
Walked a couple of kilometers home, got the Toyota and spanners came back
tightened bolts, and rode cautiously home. Picked up the Toyota later when
Mrs kutter got home.
Bloody PO hadn't tightened bolts ? No that was not the cause.
These bolts need to be tightened to 78ft/lbs. As much as some heads bolts on cars.
Three of the bolts would not tighten so I removed them.
The top bolt in the picture below is the original (25 yrs old??) Note the stretching and waisting!
The lower is a new R Series bolt. Slightly different design.(Improved?)
Rang The BM Shop in Brisbane to order new bolts. "What do you want them for? We've never had an order
for them before".
They rang back later can get some from Germany $18.00AUD+ Each.
Rang back again compared dimensions etc and they have some K series wheel bolts
which will need to be shortened 4mm. Do K series bikes have more problems with
wheel bolts than R's?
Cost is $2.50 each + postage. Bolts arrived a couple of days later, modified and installed
to 78ft/lbs.
Photo below showing bolts drilled and wired for extra insurance!
Have not seen this problem mention in any of the BMW forums
that I have searched. Has any body else had this problem and lived?
