BMW tech bulletins. What have you got?
What have you got to share?
Snowflake wheel recall.
Sticking advance weights...
Re: BMW tech bulletins. What have you got?
Speedometer advancement.
Rear drive ratios.
I have approx. 300 service bulletins, many are type 248 related for which I've produced an index below
Index of R65 Service Bulletins
11 - Engine
Engine Modification – 2031
Oil Filters-2050
Valve Clearances - 2051
Uneven Idling - 2072
Con Rod Weights - 2162
Installation of Later type Rocker assemblies on older models - 2208
BMW Engine Oil -2219
Oil Supply to Rocker shafts-2214
Oil Consumption - 2416
Repairing Cylinder Studs-2461
Engine Oils – 2568
Engine Oils – 2723
SJ Engine Oil - 2855
11 - Engine Electrics
Idle Speed Variation-2055.pdf
Diode Board-2323.pdf
Retrofitting Valeo Starter-2383.pdf
Runs on one Cylinder-2572.pdf
Charging System - 2611.pdf
16 - Fuel Tank and Lines
Matching Fuel Filler Keys-2212.pdf
Fuel Cap Lip-2244.pdf
Fuel Cap-2486.pdf
18 - Exhausts
Exhaust Nuts -2335.pdf
21 - Clutch
Fitting 81 on Clutch to Earlier Models-2037.pdf
Clutch Splines-2064.pdf
Clutch-2074.pdf
Oil Leak at Clutch Pushrod Boot-2355.pdf
Clutch Carrier Bolts-2495.pdf
23 - Fuel Supply & Adjustments
Gasoline & Alcohol-2134.pdf
81 on Air Filter Fit-2245.pdf
23 - Gearbox
Gearbox Seal-2056.pdf
Modified Gearbox-2073.pdf
Coupling Bolts-2078
Changes in 5 speed gearbox-2083.pdf
Modified Gearbox-2085.pdf
Improved Input Shaft 17.5 Deg Helical Gears-2188.pdf
Gear Oil-2197.pdf
Changes in 5 speed gearbox-22217.pdf
31 - Front Fork
Front Fork Nois-2092.pdf
Fork Oil-2079
Fork Noise-2137.pdf
Fork Noise-2190.pdf
Fork Seal Leak-2221.pdf
Noisy Forks 85 R65-2326.pdf
33 - Rear Drive
Rear Drive Ratios-1064r.pdf
Rear Drive Oil Leaks-2098.pdf
Later Rear Drive Substitution-2253.pdf
34 - Brakes
Squealing drum Brakes-2230.pdf
Rear Brake Spring Noise-2296.pdf
36 - Wheels & Tires
Runout Tolerances Wheels & Brake Discs-1065r.pdf
R65 Tires-2044
Pirelli Tires-2060
Tire Clearance02094.pdf
Wheel Recall-2117.pdf
Approved Tires-2470.pdf
Approved Tires-2762.pdf
46 - Frame
Pre-Delivery Inspection-2016.pdf
R65LS Decals-2053.pdf
Lock & Switch Lubrication-2287.pdf
Side Stand Repair-2419.pdf
61 - General Electrics
Battery Maintenance-2045.pdf
Brake Light Switch-2305.pdf
Battery Acid-2481.pdf
Battery electrolyte level mesurement-2509.pdf
62 - Instruments
Speedo Error-2756.pd
There are certainly some there that I haven't got and some (like the wheel recall) which I have in a different form (from a different territory). Can I suggest we find some way to exchange information. The simplest way might be to zip all of the files (mine are in a directory structure using the BMW designations like your index). We could also share files on Google drive or Dropbox... or even swap DVDs. That way we'll both have all of the data and can arrange it to suit ourselves.
I thought I'd already shared them with you Rob but happy to do so again. If you or anyone else that wants them, send me a PM I'll respond with a link to my dropbox public share which should enable them to be downloaded. Alternatively if there is any way the forum can host them I'd be happy to do that also.
I haven't got three of the four you posted above as far as I can tell...
If you want to let me have your dropbox share, as well as nicking everything you've got, I'll dump everything I've got into it...
Don't forget to add a couple of good ones here please.
DP55
Post by DP55 »
Please, how do I attach a PDF file?
Dirk.
PDF's are not a permitted file type probably because they can contain malicious code. You would have to take an image of the PDF and post that. The bulletins posted above at the start of the thread are images but all my 300 bulletins are PDF's which is why it would be a nightmare to post them all. It's a pity the forum couldn't host them as a reference.
DP55
Post by DP55 »
Thanks for info.
I have all the original Service Informations....... only in PDF :-(
