R100 instrument cluster plastic
pioppiny_81
Post by pioppiny_81 »
Restoring my ride I have to face a new challenge:
repair the internal columns of the instruments cluster , those that serve as housing for the 3x15 self threading screws. They are all cracked :(
First of all I would like to ask what type of plastic the cluster is done in your opinion, cause I need to reinforce the columns with
a bi-component glue but looking around I see there are a lot of different types
and second question is:
can I put M3 threaded copper inserts instead self threading screws? Have any of you already did it?
thank you all!
Re: R100 instrument cluster plastic
This MOA poster had an interesting idea:
https://forums.bmwmoa.org/showthread.ph ... ost1285750
pioppiny_81
yes I had already thought of a similar solution with plastic tubes, but I also ave to fill the old holes with something and made new grooves to install threaded inserts, I dont' think Ciano Acrylate glue is the best for that.
pioppiny_81
Finally I've fixed the columns of my istrument cluster, I used threaded M3 inserts, heat inserted using the tip of a circuit welder
before I prepared the holes with increasing diameter drill bits (from 2mm to 4)
after the inserts I reinforced every single column with epoxy 2k glue mixed with crumbled scissors cutted glass fibre
The photo is before I refined all with the dremel:
Glue seems to have a good superficial hardness and tenacity at the same time,
only time will give us a response
