Title is pretty self explanatory, I was looking forward to some suggestions/advices that anyone could give me about said swap, and if it's doable or wether it has any sense doing it
Also, what's the thread size of the rear brake master cylinder where it connects to the brake hose?
Swapping from rigid to flexible rear brake hose
Enforced_Leo44
1983 BMW R100RS
Re: Swapping from rigid to flexible rear brake hose
Well... rigid lines are intrinsically more - well - rigid really than flexible lines so they are less likely to expand under the pressure of braking but, bearing in mind the lengths of hose involved on an airhead, I can't see that it'll make any noticeable difference. Any reason for moving away from stock?
Enforced_Leo44
Not any particular reason besides style really, or maybe the ease of changing the “path” of said hose if I ever want to add some sort of accessories or modsRob Frankham wrote: ↑Sat Nov 25, 2023 8:10 pm Well... rigid lines are intrinsically more - well - rigid really than flexible lines so they are less likely to expand under the pressure of braking but, bearing in mind the lengths of hose involved on an airhead, I can't see that it'll make any noticeable difference. Any reason for moving away from stock?
1983 BMW R100RS
