Having just started to ride Mrs NHN's R80 Mono roadster again apres foot injury (walking, not bikes!) I find that the rear brake pedal too low, so that when adjusted correctly at the rear wheel I find difficulty in applying enough pressure to actually make much stopping effort. Not that the brake is much use anyway, but it helps.
So I looked to see if I can back off the stop a little to raise it....but where on earth is it? I presume it is something to do with the brake light switch and is behind the plate....that is welded to the frame. How do I access this, and indeed is it adjustable if I get there?
It would appear I need to remove the rear wheel at least, if not the swinging arm to get near it, does anyone have a clue/been there seen it done it?
Thanks in advance,
Neil (noting the glorious weather on the Isle of Man we have had is about to break because TT starts next week.
