1978 R100RS Engine Noise
Ade B
Post by Ade B »
Hi All
As mentioned in earlier posts, here's a video of the noise I'm getting. Mileage is 75k miles.
[media]https://youtu.be/UK-52KEtzsY?feature=shared[/media]
Possible pinging, timing chain, something else?
The engine badge fell off just before filming!
Be interested in thoughts.
Cheers
Ade
Re: 1978 R100RS Engine Noise
Definitely NOT pinging.
First step is to pinpoint the source of the noise.
Remove the front engine cover and have a listen with a stethoscope to the beancan, alternator and timing chain casing area, PCV flapper valve area, valve covers, etc. to see if you can pinpoint the noise. No stethoscope? A log screw driver with the tip pressed against the suspect area and the handle in your ear will work for now.
Ade B
Post by Ade B »
Thanks, good to know.
Have an engine stethoscope somewhere, will have a poke about.
Even an engine that does does have pinging would never exhibit it when the bike is stationary on the stand. The engine has to be under substantial load. With no load the engine will rev right up with just a fraction of throttle and that won't produce sufficient compression in the cylinders to promote pinging.
If you still think you hear pinging when riding the bike, just roll of the throttle a little. If the noise doesn't go away it wasn't pinging.
Ade B
Post by Ade B »
Thanks, first noticed the noise 2up with luggage after fettling carbs, valve clearances and timing. As mentioned it is very specific to a narrow rev band coming in at around 2700 rpm and stopping a couple of 100 rpm higher. I hadn't noticed it before on the stand until this weekend. Its more audible from the LHS but that might be due to the garage wall being closer on that side and reflecting the noise back as on the bike it sounds like it comes from the RHS
If it isn't pinging, its a resonance of some sort, I'll update once I've had a prod with the stethoscope.
The (edit: I read you now have a S fairing. RS fairing) can amplify any noise and make it difficult to isolate. Don't discount anything! eg, this fixed a weird noise mine had years back. Put a cable tie around the intake snorkels to take up any slack and see if it goes away.
It does sound metallic though, but you might get lucky.
Ensure the two bolts that hold the front cover are tight.
I suppose holding the rpm for a very short period whilst holding different parts to see if it disappears, eg press the front cover to see if it changes the noise?
Ade B
Post by Ade B »
Bike is back from specialist.
Bit of a journey of discovery... with a lot of 'whilst it's in bits do you want to...?'
New timing chain, clutch, one weird noise chased down to misaligned cam sprocket, which was replaced... Engine stripped and rebuilt with new bearings.
Gearbox stripped and refurbished, final drive seals redone.
New rocker bearings to one which fell apart.
Re-sleeve of master cylinder and front caliper partially rebuilt. New stop light switch...
Headset bearings adjusted
Best bit, oil starvation due to paper towels left in the sump by a PO blocking the oil pick up. Damaged big end shells replaced...
LHS header is blowing at the manifold, apparently it's aftermarket and not a great fit, patched up with paste which isn't ideal.
There is probably more but looking at the receipt is traumatic :D... the teardown identified cylinder bore pitting from condensation corrosion and worn rings, but it doesn't smoke or use much oil so one for another day. Far too much money spent but all works well beyond my skillset/time availability.
Ran it back home via the office in the sleet last Weds, cleaned it yesterday. I hadn't appreciated how smooth a well set up airhead can be. Bring on the good weather :)
zjacker
Post by zjacker »
What a saga, but it sounds like you’ve ended up with a properly sorted R100RS at last — chasing that narrow-band noise led to a new timing chain, a misaligned cam sprocket fix, full engine rebuild with new TBS bearings, gearbox refresh, final drive seals, rocker bearings, and even uncovering the oil starvation from paper towels blocking the pickup (which explains the damaged big end shells), so painful as the bill may be, you’ve essentially future-proofed the motor and drivetrain; add in the brake work and headset precision bearings adjustment and it’s no surprise it now feels dramatically smoother, as a well-set-up airhead really can be turbine-like for what it is, so aside from the slightly bodged LHS header and the longer-term bore pitting issue, you’re finally in the position to just ride and enjoy it — preferably in something better than sleet next time.
