Hi, hoping someone can help me with a speedometer setup issue I’m having. Apologies if this is in the wrong forum.
I’ve got a 1985 BMW R80 RT, with a M-Unit, Motogadget gearbox speed sensor and a motoscope pro.
I’ve been playing around with the various settings, however no matter what I try the speed is erratic, jumps all over the place.
Would some be able to share the appropriate settings, namely ImpE, ImpW and ImpF inputs.
I’ve also got an aftermarket exhaust which is loud, and I believe this can cause some interference?
Thanks
Motogadget Speedometer Setup
Re: Motogadget Speedometer Setup
I don't find those parameters having been discussed before on the forum. I googled a few and came up with these websites...maybe some useful info?
https://motogadget.helpscoutdocs.com/ar ... s-strongly
https://manuals.motogadget.com/docs/mot ... ctions.pdf
https://www.triumphrat.net/threads/moto ... gs.938624/
I have that setup. Mine works fine but I did have interference caused by unsuppressed plug caps. Swapped them and all is well.
Support is good at Motogadget?
