Removing stuck axle
Removing stuck axle
A buddy of mine just had to tow his 1983 R100RT back from a tour because of a rear wheel bearing failure. This same bearing failed 10,000 miles ago. He is having a terrible time attempting to extract the axle from the caliper mount. Seems like it has welded itself in there!
Any ideas? :?:
StephenB
Re: Removing stuck axle
Post by StephenB »
I can't help with any smart advice other than wacking it. If all else fails or in order to protect whats still there and working (such as the FD), cut the axle close to the wheel on the left hand side and cut it again close to the left side swingarm. He should now be able to remove the final drive with the wheel attached and carry on on a bench. It should be possible to remove the big axle nut and separate wheel and final drive without damaging the final drive.
Your buddy may consider buying a new wheel or have a steel sleeve fabricated as the races mostly likely spun ... once he gets the axle out. But most importantly, your buddy needs to learn how to adjust wheel bearings as they should survive several airhead lifetimes without failing. Or sue the shop that did it.
Only 10,000 miles eh?
I doubt that the axle is seized in the caliper mount, or in the final drive housing.
more than likely the bearing preload was too tight and a bearing partially welded itself to the axle.
If so, the only thing you can do is try smashing it out and see what is salvageable afterwards.
The severity of the seizure and damage caused cannot be assessed until it comes apart.
As a last resort, if a pneumatic impact hammer won't budge it, cut the axle off with a sawzall as close to the wheel as you can to remove the wheel from the bike, and then remove and replace the complete bearing stack and axle.
The hub may need replacing too if the damage is too severe.
esman100
Post by esman100 »
Before cutting and beating on it I would try soaking the piss out of it with a good penetrating oil. Most likely it is welded, but if he didn't grease the axle the last time it was a part it is possible it could just be corroded.
Jeff
Washougal, WA
'76 R90/6 "Eva"
'62 R60/2-R75/5 Conversion
GSPD is on the money......
Belt the crap out of it.
DAHIK.
esman100's idea will also assist.
StephenB
Post by StephenB »
gspd wrote:The hub may need replacing too if the damage is too severe.
It's a 1983 so it has snowflakes most likely: no hub to replace only the complete wheel.
I noticed a washer welded onto the outside caliper mount. But I don't see one in parts book. Anybody know where I can see a blow up for this assembly? :geek:
The only ones that I remember were welded tight. That is caused by not setting the preload properly.
Oh, yes, I remember one that was rusted up after about 20 years of sitting out in CA weather. Same solution, beat on it.
