Electronic Tach wires
- Jeff in W.C.
OK. I did something not so bright. I removed the tach and forgot to indicate the location of the three wires on to the printed circuit board. Can anyone tell me which one goes where? Thanks. The bike is an 88 R100 RT.
Jeff in W.C.
1988 R100 RT
2018 R1200 GS
1988 R100 RT
2018 R1200 GS
Re: Electronic Tach wires
Hi Jeff, that must be quite a bit different than the earlier (83/84) era tachs. I looked at some taken apart instrument clusters I have and that doesn't seem to apply to them.
If what Chuey says is true, these pictures of Randy's '78 won't help much, but who knows?
http://www.pbase.com/dwerbil/1978_r1007_odometer_repair
Photo #3 in Randy's photo album: (for tach wire hookup)justoneoftheguys wrote:If what Chuey says is true, these pictures of Randy's '78 won't help much, but who knows?
Brown wire - ground - top spade connection
Green - middle connection
Red - bottom connection
try this s:
red = +12, and is pin #12
brown, as usual, is ground, and negative, and this is pin #7
green is the pulse wire, it is pin #10
1I dont know how to post a link where
i found it Frank
i found it Frank
