Cool New Tool from Cycle Works
Post by Deleted User 62 »
Just perusing the Cycle Works website and found this in the Airhead 1970-95 Tools section: http://www.cycleworks.net/index.php?mai ... cts_id=367 ...a new tool for pulling and installing the timing cover and the timing gears and bearing, without heating and beating. Like the caption says, put away that hammer!
Re: Cool New Tool from Cycle Works
I'm working on not being attached. You're not helping! :|
Heat is your friend
The odd time heat is required to remove the crank gear even when using the proper BMW puller.
No tools are required to install a properly heated crank gear, they usually slide right on.
Curt Henry
Post by Curt Henry »
You get lots of washers and bolts with the tool for only $144.
Deleted User 61
Post by Deleted User 61 »
Curt Henry wrote:You get lots of washers and bolts with the tool for only $144.
I'm betting a lot of that $144 has to do with that fancy split piece with the cut-outs.
Armaguidon13
Post by Armaguidon13 »
Nice tool... But complicated and real expensive
