Oil pan extension with the cooling tubes
Hi, can anyone tell me the pros and cons of the oil pan extension with the cooling tubes?
Re: Oil pan extension with the cooling tubes
Reduced ground clearance, haveing to modify the center stand and an extra gasket that might leak are the downsides.
On the upside it is a low tech way of cooling and adding oil. It also adds crankcase volume which is needed on the 900 and early 1000s.
Unless you are draging a chair or raceing it is not realy needed. Oils today are light years ahead of what our bikes where designed to run and can stand much higher temps than 15 years ago.
but they look cool!Garnet wrote:Reduced ground clearance, haveing to modify the center stand and an extra gasket that might leak are the downsides.
In my local it will soon plug with horse exhaust.
Guy
Guy
Well I have a cafe R90 with extensive mods (both frame and motor) that I already have a late model deeper pan on but it seems to be pretty hot running at times, timing and jetting are spot on (Mukini's and Omega) Cool factor is important but not as much keeping the oil cool!! If I could figure out how to post a pic.......
Go to this thread and skip to the 3rd post:beemersanducs wrote: If I could figure out how to post a pic.......
http://boxerworks.com/forum2/viewtopic.php?f=1&t=3453
Heres a pic of my Cafe
- cafe10.JPG (122.63 KiB) Viewed 2882 times
hi to all, had one on my R90/6 a long time a go , one thing that i do remember though it was bloody heavy in weight. it looked super cool i thought.
I'm very interested in the rear mud guard. Can you tell me more?beemersanducs wrote:Heres a pic of my Cafe
As in: Where did your battery go?twist wrote:I'm very interested in the rear mud guard. Can you tell me more?beemersanducs wrote:Heres a pic of my Cafe
