R100S engine badge
Mal S7
R100S engine badge
Post by Mal S7 »
Can anyone share a close-up pic of what the original R100S engine badges looks like.
I can't tell from mine what parts are s'posed to be paint and what should be polished, it looks pretty original but chips at the edges show paint is over polished alloy and that doesn't seem right.
thanks
Mal
dwerbil
Moderator
Re: R100S engine badge
Post by dwerbil »
Here's a pic which is enlargeable from a 30 second Google search....
http://www.flickr.com/photos/kenjonbro/ ... otostream/
I've repainted a few engine badges with using a satin black paint on the entire badge. After it's dry to the touch, I use a soft wire motor brush to lightly 'buff' off the raised letters. A small dremel tool should do the trick too.
This simple technique works well.
Click for pics
Randy in Round Rock
2valve
Post by 2valve »
hi mal, pretty sure i have a set of R100S badges buried in my shed , will drag them out and have a look .
She'llbe
Post by She'llbe »
dwerbil wrote:Here's a pic which is enlargeable from a 30 second Google search....
I think the engine badge is the best looking part of that bike.
From the desk of the
Mt. Nardi Yacht Club
PO BOX 95
Nimbin, NSW
Australia 2480
02-6689-1234
DanielMc
Post by DanielMc »
Interesting - I'm pretty sure my R100S (last of the heavy flywheel) had the plain BMW badge on the engine...
edit - just found a pic:
I found that satin black followed by wet'n'dry (used wet) on a sanding block brought the highlighted areas up a treat.
I can only see a ss header pipe
How's this Mal? I can forward you a 5mB piccie if'n you want? I know, it's from a RS but the style is the same. Taken from my 11/1981 R100RS! Click on the pic, then again for full screen, then again for warts 'n all.
Mal S7
Post by Mal S7 »
Thanks dwerbil, daniel, steve,
it confirms that mine is probably in it's original, if a bit chipped, paint.
cheers
Mal
Interesting badge Steve, my starter cover only has BMW on it.
Am I missing something? I wonder if my cover is not original?
DucatiPete
Post by DucatiPete »
Mine's the same as yours Jeff... i thought all the post-81 bikes were thus. my '81 GS is also like badged.
Following recent researches i note that some late "clam shell" engines also had the the 'plain' engine badges and even the ribbed, black timing chest.
