OK I'll bite the bullit, l got another set of brake cam arms to streach
how many votes for 1/4 longer
how many votes for 1/2 longer
most easy cluth adds 1/4 and a wheel
front drum brake
Re: front drum brake
It's not that hard to predict the results. Just take the length of the stock arm (shaft center to cable point) and divide the proposed change by the stock length.
Example
IF the stock lever was 4" long, and you were considering adding 1/2":
.5 / 4 = .125
So, a 4.5" lever will have 12.5% more mechanical advantage than a 4" lever
Example
.5 / 4 = .125
- Ken in Oklahoma
And you'll have 12.5% less rotation (approximately) of the brake cam. If something like that would be an issue then a person would want brake cables, in particular the surrounding coiled wire under the jacket, to be in good shape.Major Softie wrote:. . . So, a 4.5" lever will have 12.5% more mechanical advantage than a 4" lever
That happened to me back in the olden days on my Husky 360 MXer. I wasn't satisfied with the front wheel braking so I made the lever arm longer. I probably wasn't bright enough then to realize that a stretched coils here and there could have contributed to my lack of success.
Of course Husky front brakes were notoriously feeble anyhow, so in a sense, I guess, I was trying to make a silk purse out of a sow's ear.
Please post photos?? I'd love to see how you are extending the arms. It has been on my 'wish list' for a long time but haven't even come close to crossing that bridge yet.
www.beemersandbits.com
'66 R60/2
'72 BMW 2002
Instagram - jj_withers
'66 R60/2
'72 BMW 2002
there are 2 ways to do it
weld the space added
use a steel tube, say 5/8 0blong the tube to fit the cut in the middlle brake parts add JB WELD to fill any gap rivet the the pices with steel rivits
it can then be painted
picturesmadybe if I get some help
How about using 2 arms to make up one longer arm so there is only one seam and not two? More sacrificial parts but would look cleaner.
Or are you extending both arms? I guess that would take 4 arms to do....
'74 - R90/6
Then, of course, there is the most cafe solution of all: fabricate one from scratch.
Replicating those spline teeth would be REAL tricky...Major Softie wrote:Then, of course, there is the most cafe solution of all: fabricate one from scratch.
'66 R60/2
'72 BMW 2002
'66 R60/2
'72 BMW 2002
Yep. I have no idea how it would be done, but I'm sure there's someone here (maybe Ken) who's got some ideas.jjwithers wrote:Replicating those spline teeth would be REAL tricky...Major Softie wrote:Then, of course, there is the most cafe solution of all: fabricate one from scratch.
