Removal of swingarm bearings
pxc433
Post by pxc433 »
Hi
I have done this before, but cannot remember how.
I am trying to remove the bearings from the swingarm of my 1990 R80RT. I know I'll have to put drops of weld on the races to remove, but how do I actually get the bearings out? They certainly don't seem to want to pull out.
Swingarm is off to be power-coated. 5 x Scottish winters have done for it otherwise.
Thanks, Andy
1988 R100RS with Blue/Silver 1979 paint job
2018 F800GT in Black (these bikes are great you should give them a try)
Re: Removal of swingarm bearings
Pry off the seals.
At that point, the bearings fall out.
Lay a bead of weld around the race, allow it to cool and it too will fall out.
Your question confuses me, so maybe I didn't answer your question. Weld doesn't come in drops.
Duane Ausherman wrote:Weld doesn't come in drops.
Actually it can. :ugeek:
Spray arc.
Not to say one can buy a liter of weld. :mrgreen:
A spray isn't a drop. The former is under pressure and the latter is powered by gravity.
robert
Post by robert »
Duane Ausherman wrote:A spray isn't a drop. The former is under pressure and the latter is powered by gravity.
Globular transfer mig welding drops molten metal on the weld pool. Its pretty ugly, lots of splatter. :D
Short circuit mig is used a lot.
robert wrote:Globular transfer mig welding drops molten metal on the weld pool. Its pretty ugly, lots of splatter. :D
Clearly globular transfer would transfer globs. Duane is talking drops; not dollops, blobs, sprays, spots, goobers, boogers, smidgens, bits, or . . . globs.
You let us know when they come up with dropular transfer mig welding.
robert
Post by robert »
Dropular transfer is when the molten puddle lands on your boot. :mrgreen:
Spray arc isn't under pressure.
And they're droplets, driplets, tit- bits, morsels, weeny offerings.
Boogers :roll: that's so uncouth.
I welded out my swing arm bearings a couple of months ago.
Same technique as head stem bearings.
Wouldn't the ideal swingarm bearing weldout machine be a TIG welder? No messy transfer of metal in any of the aforementioned unsavory configurations. Doesn't mean you wouldn't have to be careful, but a bit of hum and you're done?
Ken in Oklahoma wrote:Wouldn't the ideal swingarm bearing weldout machine be a TIG welder? No messy transfer of metal in any of the aforementioned unsavory configurations. Doesn't mean you wouldn't have to be careful, but a bit of hum and you're done?
Can't see why it wouldn't work Ken. Perhaps a little safer as you say.
I don't have a tig.
It would be interesting to do a comparison to see if the addition of weld metal is necessary to aid in shrinking the shell.
