More master cylinder questions
michael
Post by michael »
I got the plunger out of the master cylinder at last. Next question: the plunger looked like it had some kind of grease packed around it. Is it supposed to be greased and if so what kind of grease should I use.
Motorhead
Re: More master cylinder questions
Post by Motorhead »
NO GREASE that system is critical to timely maintence
the smoog is a mix of water rubber and rust an dirt
michael wrote:I got the plunger out of the master cylinder at last. Next question: the plunger looked like it had some kind of grease packed around it. Is it supposed to be greased and if so what kind of grease should I use.
Should be just brake fluid in the system. Sounds like long term crud build-up.
